Silly questions. For a 2 HD, 1 DVD install...
1) How nosy are these
2) How much power do they pull on idle?
Thanks
Read up TBH....
FYI, they are not nosy at all.
(not noisy either)They dont draw much power either, maybe 50w avg.
Thanks
(not noisy either)^^^
That's the wonder of a telephone call as opposed to email - especially if you don't dial the 08xx number you can get lucky!
Now ordered at £249.40 over the phone after confirming with them once again.
Fyi for those worried about LAN speeds, they couldn't be better tbh:
snip
What OS are you using? Server 2008 or Vail? or maybe even W7?
What are your disk to disk copy speeds?
Yeah and what warez/porn were you copying across the network![]()
Server 2008 R2 for the OS, copied a 10gb file across to a W7 box (Netgear switch sat between them).What OS are you using? Server 2008 or Vail? or maybe even W7?
hehe, not this time, it was an 1080 50p family home movieYeah and what warez/porn were you copying across the network![]()
65 - 70w is a high average, i've had a power meter on since i built it and max it's ever been is 100w.
This may be a really stupid question, but does that mean it only uses the same amount of electricity as leaving a 100w light bulb on all day?
Thanks,
G
Yes it is a stupid question! The answer is yes if it sucked a continuous 100w like the equivalent lightbulb, however given that even it's peak draw is likely to be aroun 65w and that when idle with the disks spun down you looking at ~30w it should cos you considerably less than leaving a light on.
Just ordered one from the manufacturer themselves, £253 with next day delivery. Couldn't get it including next day any cheaper anywhere that I could find.
YepI just wanted to check because that seems quite amazing to me.
Thanks![]()
