Current set up:
Q6600
BFG GTX 280 OC
1tb Samsung F3
640gb Samsung F3
60GB OCZ Vertex 2
Biostar T-Power I45
2x 2GB XMS2 DDR2
Corsair TX650
Asus VH222H 21.5"
The reasons for getting the Asus GTX 480 are firstly that it's cheap
But secondly because my 280 does struggle a bit from time to time because i do like playing on high settings. Also because it is BFG so i want to replace it before it breaks so that i can sell it on. Not that i think it will break but i don't want to get to the point where it does and i'm £70 less off because i couldn't sell it. I also want the 480 just because it's awesome
Oh and the noise and the heat don't bother me because i have a HAF 932.
The reason for gett the Dell Ultrasharp U2311H is that i am really starting to get into photography and would like the comfort of knowing that the monitor i am using shows the pictures the way they really are, which i am not sure my Asus does. Also, i have always wanted a Ultrasharp
So which would you do if you were me?
Thanks,
Flare
Q6600
BFG GTX 280 OC
1tb Samsung F3
640gb Samsung F3
60GB OCZ Vertex 2
Biostar T-Power I45
2x 2GB XMS2 DDR2
Corsair TX650
Asus VH222H 21.5"
Oh and the noise and the heat don't bother me because i have a HAF 932.The reason for gett the Dell Ultrasharp U2311H is that i am really starting to get into photography and would like the comfort of knowing that the monitor i am using shows the pictures the way they really are, which i am not sure my Asus does. Also, i have always wanted a Ultrasharp
Thanks,
Flare
