*** 25/02/2011 EXTENSION! *** DEAL OF CENTURY: Asus GeForce GTX 480 1536MB Graphics Card with 2 FREE
[TW]Fox;18387079 said:
Provided you are not sensitive to noise the performance for the money is sensational.
im with you on that one, its silent using custom profile on idle but playing a game its just daft, im gonna order a 470 msi i think, having said that there not silent either but that was in a much smaller case than i have now
Score seems about right, can you not get the voltage any lower, I can do 800Mhz at 1.025mV
up the voltage rerun 3dmark see if you get a performance increase
keep doing that till you reach the point where its at the maxium score
i think your throttling your card alittle
Throttling? if it don't get enough juice it either crashes or artifacts, the clocks do not throttle though lack of voltage. And please I know how to test a GFX card for stability.
Had a quick 20 mins on Dead Space 2, looks fantastic, according to afterburner the temp hadn't increased at all, I didn't notice the fan speed increase above idle, seems it doesn't even break a sweat with that game. Off to bed very happy tonight, honestly didn't expect to be able to overclock this due to temps/fan noise but got another 15% out of it very easily with seemingly no impact on noise or temps, cracking stuff :)
[timko];18385799 said:
The two molex plugs connect to your PSU and the 6pin end of that cable goes into the 480. Is this the first time you've ever upgraded a graphics card?
As for your last question, yes I believe it's only two at a time for Nvidia. If you need 3 simultaneously then you need to look at AMD's 5xxx and 6xxx series. Anything older, as in 4xxx and below, will not do 3 at the same time.
The black part goes into the card and both the white plugs go into spare white power connector cables from your PSU?
On a PSU spec, those white parts would be connected to which bit? both the 2 x 6pin PCI-Express? what happens to my 9500GT i want to keep in my system. i was going to keep my 9500GT for support for more than two monitors.
Yeah never replaced a graphics card before. Getting a new PSU as well more concerned about remembering where all the wires go lol.
"20+4pin Power
4+4pin ATX12v
8pin ATX12v
2x 6pin PCI-Express
2x 8pin PCI-Express (4x PCI-E Total)
9x 4pin Molex"
Got mine at 1.05V now, seems happy so will see how it goes. I really need a new monitor now, this 19" 1280x1024 one just isn't doing the GTX480 any justice :(
@555BUK Nope don't use over the top stability testing software that puts an unrealistic load on the GPU. I can tell you now that I'm 100% certain I would artifact in that software, but I don't suffer stability problems in any games so why should I up the volts just to keep OCCT happy.
I get stick for running 1680x1050 heh.
Yes, that's correct.
No, the white molex plugs on the cable go into the standard 4pin molex connections on the PSU. This GTX 480 needs one 6pin and one 8pin PCIe power (see below) so you won't need that 2 molex to one 6pin PCIe "Y" cable.
As for the 9500GT, put the 480 in the slot the 9500 is currently using and move the old card "down" into another slot. It will function just fine.
My answers added in green...
"20+4pin Power *** Motherboard power ***
4+4pin ATX12v *** Motherboard power, usually near the CPU socket ***
8pin ATX12v *** Same as above but you'll only need this one or that one, not both***
2x 6pin PCI-Express *** 6pin PCIe power, one required for the 480 ***
2x 8pin PCI-Express (4x PCI-E Total) ***8pin PCIe power, one required for the 480 ***
9x 4pin Molex" *** Standard power connectors for fans, CD/DVD drives, old hard drives, water pump (if you decide to water cool in the future) etc etc ***
Cheers for that mate!
Do the connectors only fit into one place i pressume so should be fairly easy to work out which is which?
Looking at my current PSU which a mate connected up for me, all sorts of wires everywhere, some black connectors plugged into white connectors, and then white connectors connected to white ones, very confusing for someone who doesnt know much about hardware unfortuntly.
Ah right, i thought that cable in the picture was standard and was needed to power the card.
Regarding the 9500GT do i need to move it down, or can the BIOS change the primary display? My motherboard only has two PCI-e slots, wasnt sure if the GTX 480 would burn my 9500GT depending on which side the fan is!
You can't really connect any of the plugs into the wrong place unless you use a hammer to force them in. They have added notches, odd shaped heads etc to ensure that each type of plug only goes into specific places. No need to worry about it so much.
Since this is your first PSU transplant, I would right down the number of things currently plugged into the old psu, preferably along with the type of plug each device etc it's plugged into.
Then check that list as you connect the new PSU up one plug at a time. Make sure you've connect up at least as many plugs on the new PSU as you unplugged from the old one. That way you can't miss any. The final count will be 2 units higher since the 480 takes up one 6 and one 8pin PCIe power.
As for the location of the graphics cards, if your motherboard as two full 16x lanes (which you probably don't know) then it won't matter which way round it goes. However, in the more likely event that your motherboard has a 16x primary and an 8x or 4x secondary slot then you definitely want to move the 9500 down. Do you know the make and model of your motherboard? If not it doesn't really matter, just put the 480 into where the 9500 is now and you won't have to worry about it :)
hmmm, seems Nvidia drivers are very bad for my old Anarchy Online I play, infact I am getting 1/3rd of the fps of my old 4870 at most :o
Yeh lol. I'm getting this aswell using the latest nvidia drivers. A lot less fps in anarchy than when I was using my gtx280. I might try some older drivers. And see if it sorts it. Dosnt bode well for anarchy online though. Hope they hurry up and finish new graphics engine
Oh I wouldn't say card is loud either. At least at idle. I've not really pushed it much though yet. Will at the weekend.
Hmmm... glad I kept my 560 soc pre-order, might just bang it on auction without testing tbh when it arrives, might even make a profit ;)
