I'll describe the problem in as much detail as I can. Please request any information you might need to help me solve it.
First of all, here's what I have:
Now to the issue:
It took a little while to install everything, but I finally got all the pieces together, connected a screen and tried powering it up. My PC starts whirring and the LED on the motherboard is lit up, but unfortunately there is nothing on my screen - "No signal". All fans are working properly it seems - CPU cooler, PSU and GPU. They do sound a little strange however - like the system is restarting itself every second - fan speed goes up and down.
I've tried removing the graphics card and plugging my monitor into the motherboard, but no luck there. Also tried moving the RAM around, using one stick, making sure they're properly fitted and things like that. As a last note I'm using a screen which only has a VGA connector, so I'm using a VGA to DVI adapter if that matters.
If there is anything you think I could try to get it working I would be very happy. Starting to ship things back to the UK is a big hassle and will probably cost me a lot of time and money.
Edit: One thing I noticed during my endless googling about my problem, is that my motherboard only has a 4 pin atx12v connector. Could this cause my problem? Is my CPU getting enough power? I am not very exprienced and I have no idea. Just thought I'd add it.
- HIS ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card
- AMD Athlon II X4 Quad Core 640 3.00GHz (Socket AM3)
- Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard
- OcUK Crusade 550W Dual-Rail High Efficiency Power Supply
- GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel
- Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS)
Now to the issue:
