- 8 Aug 2010
- Oxfordshire
Op, take the side panel off, if the card is still loud then the card is faulty, simple.
I've done that already as mentioned 4 posts up and it's still loud in-game.
Taking the side panel off does not generally help, as RealDeal said, this is because with the panel on your case creates a wind tunnel effect from low front to high back, by removing side panel this effect is lost
Or read/watch a review first and if its above 30db then you dont want it.
Your card is faulty then mate, either the thermal paste hasn't been applied properly or the chips is leakier than Delilah's bucket.
Air flow is simply not the problem, and "doh" to the posters who still saying it is.
Off course airflow matters as hes looking for a quiet card and he will not achieve this if his case is full of hot air as any gpu he buy's will run hotter and the fan will run at a higher rpm to compensate.
Yeah 38db is not silent at all unless you live in a factory.
All of my fans (watercooled) are circa 20db and it's perfect imo, I mean you can obviously still hear them but it's not distracting or ear ache inducing it's just a pleasant humming sound (I use S-Flex 1200's)
Hes searching for a quiet card ejizz end off if that card is faulty then its faulty but the fact remains a cooler case will lead to a quiter card. Hes even thinking about quitting gaming if he can't find a quiet card. He has 1x120mm intake and 1x120mm exhaust its hardly great cooling. You say its adequate air flow but its not adequate for the noise levels hes looking for. I had a similar setup on my kandalf and that struggled to keep my 5770 at decent temps as the heat was not exhausted out the back. I then stuck in a much bigger 6870 which does exhaust heat and all my temps dropped. The reason was my case never had enough airflow to deal with the extra heat being dumped in the case from a 5770 which is not a hot card. All my heat and noise problems were solved in one purchase and that was a much better case. This is from experience not quess work.
My mate moved from an akasa eclipse to a corsair obsidian 700 and hes finding all his components quieter also. With the akasa in recent years he always had the side off to keep things cool. Sitting at his desk was like being inside a twister noise wise. Since his new build things are much quieter and his machine has a 5970 inside which is not known to be a quiet card.
I'm sorry to say your just wrong. To start with you have ignored the fundamental fact the problem still persists with the side panel off.
Bottom line he has purchased a VERY COOL and quiet card, that SHOULD remain quiet despite high ambient air temps.
If it's airflow, why isn't his system shutting down from his CPU overheating, or locking up from his NB overheating?
Yes good airflow may help temps by 10-15c but that's not what's causing the card to ramp it's fan's up to 90%.
I am not talking about the card lol so i am not wrong. I am talking about his overall wish to have a silent card. The thread is not about if the card is faulty or not its about him wanting a silent gfx card. He sounds like a guy that wants best results when it comes to a cards noise level and he simply won't achieve this with the case cooling he has atm.
Fact is, if the card wasn't faulty, it would still be silent (or close to silent), even in a case that had 10-15c higher ambient air temps.
Increasing airflow in the case, with higher rpm case fans, or more case fans (due to echo), will itself create more noise. Increasing fan speed or adding more fans would only result in a net lower noise level, If the cooler on the card was crap and noisy compared to the case fans, which in this case, they are not.
This is starting to cost me an arm and leg now plus it's starting to stress me out, all I want is a silent gaming GPU, do they exist?
A card can highly be running silently when the case is like an oven.
TBH, i don't think the case is the problem.
The card would probably be louder than one in a better case like antec 1200 but the noises described are too much
I'm not sure where youre getting this info from, fans echoing off each other etc, but its not the case, you can build a perfectly quiet system, this system will have quite a few fans to keep it cool, large slow spinning fans
Temp and noise ARE directly related, if the ambient temp is high, then the cards base temp is already high, so when it loads up its even hotter, the hotter something is the more air needs to pass over it to cool it, this means the fans need to push more air by spinning more/faster, this creates more noise. So to say airflow does not matter is simply wrong, airflow has a large part to play on temps and therefore noise
