just got an email Your order has been shipped is this a good sign?![]()
Tricky one as the ratios between different sub-systems are different between the 470 and 480. So as you wind up the clock speeds some stuff very quickly matches or overtakes the stock 480 whereas other areas are still slower.
750MHz will match a stock 480 in many cases in older games at upto medium resolution and lower levels of AA. But for newer stuff your looking at 800MHz. To absolutely match or beat a stock 480 in every regard you'd need ~840MHz (which is the upper end of clockability on the 470 with safe voltages) but at ~840 you'd be quite a bit faster than a 480 in most areas.
Got it installed and running (after a lot of faffing about - the CPU cooler I ordered had a duff fan, so I had to switch back to the stock one). Just tried Metro 2033 on DX11, max settings except for advanced DoF on 1680x1050 and it runs very smoothly and looks great.
As I'm typing this, it's idling at 40c at 40% fan speed and I can barely hear it.
