Mine is 70.00.35.00.00
My 44% fan speed is 1950RPM as well. It's.... audible. Not really loud, but different in tone to my case fans, I thuink.
My case fans I've always thought were quite quiet (though I guess other people might think they're too noisy), but they give a gentle swooshing sound. No buzzing, vibrating, motor noise or anything, just the "whoosh" of air moving. It's perfectly okay.
Now, I don't actually think the 480 at 1950RPM is louder, but the fan does have a slight-but-definite buzz to it that means I notice it's there compared to my 460, which was completely inaudible over my case fans.
It's nowhere near as loud as I was fearing, though. When my HDDs are accessed they are still the loudest thing in my system by a distance.
With two monitors, it seems to have stabilised on auto fan profile at 64C and 44% (1950RPM). This is... okay. I can live with this. Would like to overclock, but we'll see.
Thing is... I have yet to try any benches or games... :/
I am used to noise when gaming due to my Sharkoon SE CPU fan spinning up to 2000RPM, but I have headphones and I know that's a noise level my wife can live with too (bar the very occasional complaint).
So... onto gaming, but I'm feeling really relieved that all is bearable at idle, as that was always going to be the main issue.![]()
Managed to mess around with my card a bit last night, but I had a complete curve-ball thrown at me - turns out the BIOS version for my Bloodrage GTI did not support the 4xx series properly. So I had a nightmare experience of the motherboard not posting with some obscure error code on the LED.
Well, that's the stuff we live for as PC Gamers right?![]()
So I eventually figured all this out, swapped out to my GTX280 again to update the BIOS, reinstalled the 480....and success! However, now my OC settings on my i7 are not working anymore! Hilarious and annoying at the same time, but **** happens. I have not benched anything yet - will sort this first I think.
[TW]Fox, really sorry to hear your experience of the card thus far. For my part, at idle the fan noise is exactly the same as my 280. I suspect at load it will not sound much louder than the 280 was, but as soon as I can get my system stable and overclocked again I will give it a go and report back.
Anyone have questions, feel free to ask.
Ok, at 760MHz core, I get a 25% improvement over my GTX460 @885MHz core (44.2 ave fps & 1114 points, vs 35.3 ave fps & 887 points).
Does that seem about right? I did think it might blow my old card away a little bit more comprehensively than that?
Went up to 86C over two runs and seem to stabilise there with 62% fan speed. Overall, my CPU fan @ 2000RPM is probably louder, but it did sound like there was a battle for noise supremacy going on in my case. Please I game with headphones... and my wife working behind me on her laptop didn't complain, so that's good![]()
^^ Wow. Nice temps. Max of 70C for a Heaven run is amazing compared to mine! Any special case cooling? I have a HAF932, which I would have thought would be amongst the best cases to keep a GPU cool...
Whoah, yeah. That is going to be much more airflow than my slow-spinning single 230mm fan! How's the noise with that set-up?
To be honest there is a constant drone from the 8 x 120mm fans in total + the CPU cooler and PSU fan, but as i have the case for 3 years, i have grown used to it.
Did you by any chance note the 480's bios version? there's seems to be quite a varaition in default fan speeds
Mine at idle, 44% fan speed 1950rpm, GPU temp 36C
GPUZ ver 0.5.1
ASUS bios ver 70.00.35.00.00
Nvidia driver 266.58
Mental, after 3 years i would be deaf
[TW]Fox;18393830 said:Just checked, same BIOS version.
