1920x1200
That's the thing, my actual system is not exactly silent, I have the two 120mm Antec fans that came with the case, front and rear set to medium and an 120mm Akasa amber on the top set to 50%, plus my CPU is using an Arctic Cooling Freezer 7 cooler set to full, so my system although not loud is most definitely not silent, the thing is my system just 'hums', you can't actually hear any fan motor whine if you know what I mean, your mainly just hearing the air being pushed through the vents which I don't mind too much, you can have a low db fan that can be an annoying pitch even though it's at a low volume, and then you can have louder fans at a more acceptable pitch.
It's really hard finding that right type of noise that is acceptable becuase it's not just down to db's.
Anyway while I'm waiting for my RMA on the GTX560Ti I think I'm going to purchase the
MSI GeForce GTX 460 Cyclone for now and then I'll grab a GTX570 once I get my refund but I'll keep the thread updated.
