*****Another EPIC DEAL - 3TB Hitachi ONLY £134.99 Delivered!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well were making it easier for all our customers to enjoy the super-fast 3TB HDD's by been the first to bring prices down, check this storming deal on the superb Hitachi 3TB HDD:-
Hitachi Deskstar 7K3000 3TB SATA 6Gb/s 7200rpm. @ £134.99 inc VAT
The Deskstar™ 7K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 7200 RPM performance in a standard 3.5-inch form factor. The 7K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Part Code: HDS723030ALA640
- Capacity: 3TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Bootable with Sandybridge P67/H67 Motherboards
- Warranty: 3 Years
Was [169.99] Inc. VAT
Only £134.99 inc VAT - PRE-ORDER ONLY PRICE UNTIL THURSDAY!!
ORDER NOW
Hi there
Our suppliers are on the ball at the moment, stock has arrived, price shall be honored until Thursday as promised. :)
as good as the F4's are though they are eco drives, i have not seen benchmarks of these hitachis but as they are 7200rpm i think it is a safe bet they will be faster.
what is the platter size of them?
Only if you want to boot from it. Otherwise all that is needed is an OS which supports GPT partitions (Vista onwards)
Can these drives be used without using GPT partitions? a have a sumvision media player that has a 2TB drive in it, if i change the drive to GPT it's still accessable in windows but not recognised by the media player.
No. The MBR partition table cannot define any partitioned space beyond the 2Tb limit. There simply isn't space within the partition record to do it.
