if you have a little spare time
im having alook there and im finding prices which seem to be the same i5 but much cheaper? is there a way to talk for faster through something IM or this will take awhile
you will have to reply here or can send a message in my trust button.
its the OEM versions of the chip, 1 year warranty and no heatsink and fan.
do you have any i5 that are 3.3ghz or close to that for around £180?
they dont need too run at 3.2 when they run at 3.3ghz
you cant compare a new i5 2500K against the older tech i7 950, the sandybridge does more work per clock cycle.
ok im looking at motherboards on the overclockers website now....
Intel 1155 SandyBridge (P67 Chipset)
Intel 1155 SandyBridge (H67 Chipset)
Intel 1156 (P55 Chipset)
Intel 1156 (H55 Chipset)
which sandybridge motherboard to i click on the p67 or h67 of the cpu i choose for that one i just showed you?
select the one in the picture above.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-432-AS&groupid=701&catid=5&subcat=1906
this motherboard will allow you to add a second graphics card in the future.
i know i will and i got people who can help me but i need to do this
1)i need a new computer
2) my course at college this is one of the things i need to know how to do
if i kept my current harddrive i am wanting to use would that still be all ok with the compatability with the motherboard because it is SATA 6Gb/s which is the
Western Digital Caviar Black 1TB Hard Drive
1TB Western Digital WD1002FAEX Caviar Black, SATA 6Gb/s, 7200rpm, 64MB Cache, 8 ms
will 650W be enough aswell for long time because i heard overtime the W drops because of age and i don't it to stop to low.
Also my case http://www.overclockers.co.uk/showproduct.php?prodid=CA-175-CM would that be ok with my motherboard aswell or is the opne you link me to a better choice?
Also i might increase the RAM to dual channel of 6gb altogether if that is ok on 1600Mhz
also im not to firmilar with Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive is therew quick summary of these? or?
