system restore off/on
10 Dec 2010
sussex
still trying to get to grips with my ocz 60gb ssd drive vertex 11 ,with regards to space saving im trying all sorts off things ,mostly done by googling advice even down loaded a ssd tweeker from the ocz site although it costs a few quid ,just gives the safe option of turning thing on /off as you require ive done the ahci thing in the bios ,even down loaded a restart timmer to see how quick it restarts i did get about 65 seconds , i also started to alter the pageing files sizes although not sure if this good if you have not got to much ram installed ive only got 6gb ,also tried remmoving unwanted programs im sure ill find a few more ,just wondering if its safe to turn off the system restore ?this gives me about 15-16gb back ,ive brought an external drive all be it a cheap one from the supermarket 1tb hitachi simple for back ups ,some one on the the ocz forum said always back up so i have.also installed all me other programs on the other drive internal 1tb. also done the hibernation off although this is given as an option in the ssd tweeker ?well ive got about 15gb left with the system restore on is this a safe amount to keep my system stable .?
you dont have to turn off the system restore but if you have 15-16GB's worth id deleate some of the older restore points if you have no problems with how your PC is working atm
ive a vertex 2E 60gb and i have no page file (i have 6gb of RAM like you) and system restore turned off and im ok with it, no problems to report.
ok do i move all of these twice ie in admin and my user(paul) it seems im creating 2x files for each music,video,pictures ,downloads ,contacts ,etc .it also wont allow me to move public, docs,music,video etc to the hdd drive ,all gets confusing with so many files?
You can change the amount of disk space reserved for System Restore in Windows 7 (but not in Vista). Just set it to something like 5 GB and then it'll only keep as many restore points as it can fit in that space.
Turning hibernation off will indeed free some disk space but some methods of turning it off don't actually delete the file. If you still have a hidden "hiberfil.sys" file in C:\ then go to Start, type "cmd" and press Ctrl + Alt + Enter. Then type powercfg –h off and press enter. All gone.
he doesnt mention what os hes using but of course you can set system restore in vista if thats the os in use, just needs to be done via command promt (cmd)
here you go
http://www.howtogeek.com/howto/windows-vista/reduce-system-restores-disk-usage-in-vista/
