- 8 Oct 2004
Sell the cpu/board and 12GB of ram and buy Sandybridge.
sandy is currently slower at stock speeds than the 970. as i say I don't o/c, so I need the extra 2 cores.
http://www.anandtech.com/bench/Product/288?vs=157
£180 2500K vs the £460 970. slower? only in a few tests.
The 3dsmax tests?
Then going back to the the 2600K vs 970 link at the top of the page - http://www.anandtech.com/bench/Product/287?vs=157
the 2600K just edges ahead, not bad for £231 for the OEM if you have a heatsink, or £275 for retail.
it does appear to. but i seriously doubt the validity of their 3dsmax testing, since v9 is extremely old (we've had 2008, 9, 10 and 11 since then!). I would like someone to do some up-to-date benches using max 2011 with mental ray or vray for example.
do these mean anything?
http://ixbtlabs.com/articles3/cpu/intel-ci5i7-lga1155-p2.html
http://www.guru3d.com/article/core-i5-2500k-and-core-i7-2600k-review/14
And dont worry about the SATA port thing, it only affects four of the SATA2.0 ports, ASUS boards have loads of better SATA3.0 ports.
And you can swap out the board at anytime upto the end of the warranty time, and then receive a working board with a reset warranty period.
so the £800 980X cpu is faster? than the 1/3 price 2600K?
Why bother getting such an expensive CPU and only running it at stock speed?
Getting at least 4 Ghz out f these CPUs is childs play.
well yeh. it's terrible value for money but... we're talking about how much power you can get at stock speeds in one machine. if i want i7 980 speed out of sandy I have to buy two sandy machines = more expensive overall.
But would not, the price of two 2600K pc's be worth the performance increase/return in work done/time saved compared to a single 980X cpu?
1366 will remain top (but rather expensive) dog until Ivy Bridge arrives.
