Hi guys
I have a 6950 flashed to a 6970 but every time i try to run bad company 2 on all out maximum settings i get really bad stutters in the game especially at the start it jumps down to 4 FPS for about 3 seconds then back up to 60 until i run into some action then about 45 FPS. I do have vsync enabled. I thought this card is more than capable of running this game at maximum settings ?
Iv also tried it on counter strike source on all out maximum settings and the game seems a bit choppy. Heaven is reporting back high of 54 FPS with a score of 1460 ish.
I have the latest drivers installed. Running at 1920 x 1080
AA = Application controlled
AA Mode = Adaptive Multi Sample
AF = Application controlled
Texture Filtering Quality = Quality
Vsync = Off unless application specifies
Enable surface format is ticked
Any ideas or thoughts or is this normal ?
Just to add when my FPS started to drop the CPU fan sounded like it was dropping in speed too then back up again.
