- 24 Sep 2008
- St. Neots, cambs
Ive upgraded from a 5850 to a gtx570 added new red braided cables and 120mm from bitfenix!
Finished
Running like an absolute dream![]()
Use the braided extension V R, i got one for my lian li a70f, was a godsend tbh as the case is quite tall and the corsair 8 pin cable was to short.
You can make out the extension cable on the right, have it clamped to the mobo tray to keep it in place.
You would need a tool like a Dremel to cut the hole, other options are cnc cutting, this will be a lot neater, but it will cost a bit more.I have a P182 case and would like a MoBo CPU access hole just like this case.
Has any got any info on how to go about doing it ! ?
i am gonna cut a hole in my antec p190 next time i upgrade the mobo and cpu, pretty much all mobos have mounts in the sanme place just cut a slightly larger hole than your current one needs
Looks great, has it helped to improve your gpu temps compared to the zalman.Just transfered from a Zalman GS 1000 to a Cooler Master HAF X
Wouldnt you be better with Apache fans on the Corsair im sure they would give you better temps than the Bitfenix fans.
I have a Dremel, so it is game on !
The main problom I see is making the hole suitable for most motherboards. i.e if I cut a hole for my ASUS MoBo, what happens when I up grade to say a Gigabyt and the hle is in the wrong place !
That is my main concern.
