- 23 Nov 2004
The input shaft did have quite a lot of play on it though?
Aye it was sliding side to side quite a lot but did appear to spin smoothly.
Aye it was the alligning it back up that was tricky with us. Wriggle and push for ages then it just sort of clunked into place.
I imagine the gearbox and clutch for a mustang are quite a bit bigger than a wee almera![]()
It moved side to side in the bell housing?
That not too bright. However, if the box otherwise operates well I wouldn't concern myself too much atm the clutch/flywheel will centre it anyway. It may just be more prone to leaking box fluid and possibly spoiling the clutch plates however.
Was the release bearing replaced also?
. Here was the old box....with loads of oil everywhere.
