i5 or i7
3 Mar 2010
Staffordshire
As I’m not a gamer (other than online poker) and use my pc for the Net and Photoshop (several large picture files open at one time) and general office stuff. Would I see enough benefit between these processors to spend the extra £66? I will not be overclocking, so locked CPU isn’t an issue. The one thing I do want is files to open quickly.
Intel Core i5-2500 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail [BX80623I52500] @ £169.99
Intel Core i7-2600 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail [BX80623I72600] @ £235.99
Thanks
i5 will be fine for that unless your doing heavy video and image post processing.
But yea depending on your system an SSD might make a bigger difference!
Yes I agree they do look negligable. I had looked at the comparison prior to asking the question as although I can see the figures, they dont mean that much to me being none too technical :) Its difficult for me to judge what the difference would be in the real world.
They are so light that you can stick it anywhere in your case with a bit of tape or velcro. I know people that have done that.
yep mines just lying on top of a 3.5inch drive not even taped down and temps are only just above ambient. They are amazingly light probably around the weight of a 20 pack of smokes.
I don't think HT could bring much performance improvements. SSD is the way to go; however keep in mind that the performance of MLC degrades fast.
HT = Hyper Threading. If you're a gamer you'll get no real benefit from this as I don't think any game uses it.
MLC = Multi-Level Cell, which is one of two ways solid state drives use to store data (the other being SLC - Single-Level Cell). SLC drives last longer, but MLC drives should still last you a good number of years unless you hammer it every day.
