- 19 Dec 2010
- Staffordshire
Maybe try a small dab of liquid nitrogen to freeze it and then smash it with a hammer?
Much more likely to smash the plastic its bolted into.
Probably best to use a hex key in this case!
Yes, that would appear to be a Torx, although it seems someone has attempted to have a go at it with something other than a Torx screwdriver already...
just looks like a standard allen key head, not torx.
rasta clot screw face ting?
seriously has anyone ever owned a bike?
Allen.. deff, but you can prob force a torx driver into it![]()
It's probably a bit sad but that chart is brilliant!![]()
It appears to American.
What it says is a 'set screws', I call 'grub screws'
A set screw toi me, is a 'bolt' that is threaded right up to the head.
A bolt is only partially threaded.
Phillips and Pozidriv screwheads are different and not 100% compatible.
It doesn't list Torx.
It doesn't list spline drive nuts and bolts.
) UK one.
