Can you ever go back from RWD?
Probably. Other things wear out though ie. suspension components.
Why do you want an AE86?
Yeah Tim, I know. But I meant properly maintained, everything just as new as it left the factory 24 years a go.
I'm not thinking of buying one, was just putting that car into the question since it's quite an old car now.
Just stop talking about things you don't seem to properly understand.
For a person who is usually the first to jump on somebody when they make sweeping statements on subjects this is all a little bit embarrassing coming from you.
I take it all back, the average 1994 Rover 200 is in pristine condition inside and out and is more than capable of returning a 0-60 run of 6.2 seconds without any remedial work whatsoever.
The car could be completely worn out and in shabby condition but unless the engine has serious issues (unlikely unless it has been totally neglected, i.e. thrashed constantly from cold, low or poor quality lubricants throughout it's life, improper cooling etc) or it has done absolutely stratospheric mileage, then there's no real reason why it can't make at least close to stock power, and thus still have most of the performance it ought to. Whether that performance drags you into a hedge due to every suspension bushing being worn out or not is neither here nor there :p
Precisely.
All engines wear over time and drop a little bit of power, despite what a set of over reading rollers seemingly suggest to some members.
That being said something would have to be pretty wrong with an engine to drop enough of a considerable amount of Power for it to make its book 0-60 time a distant dream.
I made 6.58 in my random stock 220 coupe turbo remember, which is acutally heaveier than the standard gsi turbo
It does seem odd driving a FWD car after driving a RWD car for a while, but it's not something I will completely discount.
I don't really think they are. In standard form they aren't even fast? They just seem to be a drifters wet dream:confused:
I think its the fact they have so little power but are so well balanced that makes them drifters wet dreams, you can nail them the whole way through a drift unlike most other cars, also Im a drifter so its my wet dream :P
AWD/4WD is where it's at. RWD is fun, in the dry, I've been there and it's good stuff. But 4WD trumps it. That said, depends on how you look at it, how you prioritise things on the road.
Rover turbos, happy memories of mine. So easy to drive the maximum potential. I like front drives.
My S2000 really requires commitment to get the most from it and to be honest RWD probably has little advantage off the lights due to the power delivery.
.... but is there anyone who has extensively owned RWD cars and then gone back to FWD and not regretted it (i mean FWD exclusively, and not an FWD for work, and a RWD weekend car).
FWD has its advantages, it requires far less effort and thought for one.
Dont ever drive off guard with RWD is my main memory and it was a while ago now, FWD is so forgiving in comparison or maybe that was mostly just the cart horse springs on a volvo 340 that did that but the edge is very soft on FWD and RWD it very often aint.
RWD preferred but fwd is best for most trips. Ironically I think RWD balances a car far better, not sure why but done right its much better through curves
I've never driven anything (for a meaningful amount of time) other than front wheel drive cars.
So tbh, i'm in two minds about what to go for next. Part of me would quite like a change, but the other part is used to how FWD behaves and would rather not venture out of that "comfort zone".
I'd rather my rear wheels driven than front, and can't think of a FWD car that I would want over a RWD.
As for power loss over age / miles, my very well maintained e39 is certainly down on power, not by much, not at all,but its down - I'd say - I've not had it on a dyno or anything.
Its 13 years old & has been to the moon & is on its way back!
Hardly surprising tbh.
Well i went from an RX7 and RX8 to a Ford Fiesta XR2, and i have more fun now. RX7 just wouldnt drive in the wet at all. Im happy with FWD it can be made justs as fast upto a certain power level.
ive owned both, personally i prefer fwd, simply for ease of use and maintence..
I do all work on cars myself, and rwd/4x4 just makes it far more difficult on a drive.
You can't really go ahead and make sweeping statements like that because it really all depends on the car. For example my RWD Soarer was noticeably more 'forgiving' on track than my FWD 205.
That's because it's a barge.
I find an S500 more forgiving than my DC2.
