OcUK Minecraft Server - Rules & Chat
If people are still up for playing around on the LinkTart server a bit, I just got nether gates working. There's a gate setup near the spawn point.
I built a gate quite a bit away from spawn but there was no return gate when I entered the nether, do you have to make your own or are they supposed to be generated automatically like in single player. Also unable to mine blocks in the nether though I can pick up blocks blasted by the ghasts. Any help appreciated :)
The nether looks epic, syl if the map is moved and the nether works after you think we should carry on with the plan of blasting a cave or should we finish stairs make the entrance hall/paragon hall and then at the end have a portal into nether and we'll build in there?
Problem is while it's a massive ready made cave and has ready made lava lakes, all materials will have to be brought in, ie stone etc and the scenery will be mismatched with the nether stone.
Love the idea of this, getting ported into the nether and building a base there ;)
yeah you have to make a gate each side it seems, also the portal area seems to be a spawn and is protected and you cant dig next to it, you have to move away.
If we can port the map over will we spawn where we last logged off? or will it be at the normal spawn. Just thinking it might be interesting to try find my home again since i walked away from spawn in a random direction lol.
Anyone with a vault may want to remove there stuff before the map is moved over to the new server, not 100% sure if they are going to be protected on the new server.
