- 4 Mar 2009
- United States
Is there a way to run 2 routers in the same network wirelesly ?
Crossover cable, from the main routers built-in 4-port switch to each additional routers built-in 4-port switch.
Switch off the dhcp server on each additional router.
what is a crossover cable ?
i would like an additional acsess point so thati can have a good connection all around my house
Hi forum I have read this and this it what i want to do sort of,
Can someone advise if the below is correct,
Im getting 100mb super hub installed on friday which will be the main modem/router
I want to connect my current netgear WDNR3700 to this super hub so as to keep my original wireless settings for all my devices,
The only thing i need to change will be the existing routers ip address???
Does that sound about right
Cheers
