- 22 Mar 2009
- Cornwall
yeh, and when the new AM3+ mobos come out then that will be my next upgrade, ready for a bulldozer when money allows
dont get that with intel
dont get that with intelPlease remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
dont get that with intelunlocking cores will lower the max potential overclock because two more cores are producing more heat, and more heat = instability. however, this usually only translates into 100-200mhz lost. For example my 555 will top out at 4.0Ghz as a quad, but i can push that upto 4.15ghz as a dual (turning off the extra cores is just as easy as turning them on by the way)
in terms of price, the 560 aint really worth the extra 11 quid or whatever it is. The dies are exactly the same and are likely to be from similar batches, so both will overclock more or less the same as they both have unlocked multipliers
damn these chips seem to be pretty good value for money![]()
They are excellent although you do take the chance of it not unlocking at all.
I did a lot of research before getting mine and it looks like they have a ~75% unlock rate to at least a tri core.
am i best resetting my bios before i take out the 250 or will it know there is a different cpu and reset it itself?all ordered so will be here tomorrowam i best resetting my bios before i take out the 250 or will it know there is a different cpu and reset it itself?
well its arrived, thing that concerns me is the HSF looks smaller than the one i got with my X2 250![]()
oh well, got the rest of the week off
) if temps are high or stopping me pushing on.The individual core temp sensors won't work when cores are unlocked. You should still get a reading for the whole cpu though.
well its in, all 4 cores unlocked and its loaded into windows both times of asking, but now CoreTemp is showing as 0c so trying to resolve that before any testing.
