no
only rev 1 cards work
Is the Asus (linked above) best one to go for?
If not please can someone recommend one? Not interested in package content i.e games etc.
http://www.megaupload.com/?d=8FHEMTE0
Bing
A whole unlock thingy with the ASUS bios, gives you extra voltage for free, a tiny OC and unlocked shaders. Perfect?
And it's no worries, happy to help![]()
thats 1gb
That's what I used:So ideally what bios should I use to flash the Asus 6950 2gb card if the above bios us only for the 1gb card??
Depends how you unlocked it, if it's shaypers method then yes, it will still be id as a 6950. If you compare your gpu-z with mine above you should have the same amount of shaders as a 6970(1536).Got my asus 6959 today and have just now flashed it to 6970, should Asus SmartDoctor still id the card as 6950 or 6970 in the top left corner of the program window??
