Just installed a 6970, and a strange problem.
19 Oct 2002
Torbay, Devon, UK
I have just upgraded from a 5850, removed installed the drivers. Plug new card in installed 11.2s.
I have had no problems while using the PC. But if I leave the PC it locks up. (I have not timed it but say anything more than 20 - 30 mins).
I have a good PSU 750 Enermax.
Anyone got any ideas.
Is the PC "on" all the time or do you use the power management settings to put it to sleep,sure this is mentioned elsewhere on the forum as a problem.
I thought it was when the monitor when to sleep. So I set it to never go to sleep. I dont set my PC to go to sleep any more as it never wakes any more. So my hard drives are set to stay on as well as the PC.
I have checked the connections.
