Thats 3 slot right?
Double, same as most high end cards in the last 4 years.
Thats 3 slot right?
according to sources, this card Wang HD6990
Effect of the heat depends on case cooling. I use only 2 Nexus 120mm fans @ 700rpm as exhaust (which work at loudest noise level I find any 120mm tolerable). This is good enough to get rid of heat produced by CPU but changing stock to aftermarket on gtx 580 raised the CPU temps by 6-7 degrees. Obviously adding another 250W of heat is not completely OK.
Thats 3 slot right?
Then I don't understand. Was it top or rear exhaust ? (I assume the CPU sink fan was oriented to push air in the same direction as exhaust)Well initially this was in a system with a single 750RPM Nexus fan an as exhaust and no intake.
Soooo...
like i said b4 when the 6990 comes out 2 580 wont touch even one 6990
i like this comment
