The name of this new beta bios is "P67 Extreme6(142)"
Bios file name is "P67EX61.42"
Direct Download link here http://europe.asrock.com/downloadsite/bios/1155/P67 Extreme6(142).zip![]()
Did You get your board back to life ?
Only setting the short and long power higher will allow it to hold higher multipliers, I upped long duration from 95 to 110, what do you have ?
side note, I have had a couple of bluscreens in prime now![]()
No...I tryed again last night with no luck..Did You get your board back to life ?
No...I tryed again last night with no luck..![]()
ok checked bios when i got in and its at default 150 i say default cause i havnt touched it, everything else says auto
while i was there i dropped offset to -0.06 cpu z now reports between 1.28 to 1.328 primes been running for half hour so far and temps still hitting 75 average 1/2 & 71 0/4
anyone know how long artic silver ceramique takes to bed in?
Mate, You would not believe I have 11 A4 sheets from testing !! if You use full manual settings You can get the job done about 3 different wayswhat preset r you running now?? a few peeps have the h70 with vipers and oced sandys supposedly not hitting 50 so i think im gonna grab some as5 from work tomorrow and try reseating, also i think i may put the corsair fans back on as the pc is in a different room to where i am sat so pwm function dont really matter.....in fact thinking about it now i dont even know why i changed them!
Posted (RMA) my motherboard back to OCuk today...My motherboard is now failing to boot...does not even get to the bios screen
Tryed pulling out all memory and swapping slots & tryed using single stick in each slot..
Tryed clearing the cmos by rear switch & jumper on board
Tryed removing battery
Tryed with only a single GPU card (both slots)
Tryed with all USB items/cables ,network cables, hardrives etc,etc removed
And still does not work![]()
(Now using my old 775 board & CPU)
Looks like it RMA time for my Extreme 6....
Wonder how long it be before i receive one back...
I asked for it to be replaced with the same board...So once your board goes back are you going to get the same board or would you swap for another ?
Got this reply back from OCukPosted (RMA) my motherboard back to OCuk today...
Looks like it must be my CPU or ram that is faulty...Here is the technicians Test Report:
"Motherboard posts with all memory slots filled with no issues (bios and windows), also test with one stick in different slots, please try again and check other components for faults / incompatability."
Seems like it my i7 cpu that is faulty as the HTPC i have just built will not boot at all with my i7 2600k cpu.......But boots fine with my i5 2500kNot the first time I've seen that, taking everything off the board and leaving for a day or so, or just re-mounting the CPU and it's back to life, It was just the cmos that was a little scrambled.
I Just been on the phone with OCuk for my CPU RMASurely a waste of time getting it back when the replacements should only be a few weeks away ?
1. Improve mouse fucntion under BIOS setup.
2. Keep User Profile after clear CMOS.
3. Patch 15" CRT monitor for BIOS setup.
I've seen some with V3 but when I questioned them they admitted that this is not the same as B3.
How to identify Intel B3 Stepping Chipset message on ASRock P67/H67 Series motherboard?
(I) You can find “New B3 Stepping Chipset” logo on the gift box.
(II) You can find "New B3 Stepping Chipset" sticker on the motherboard PS/2 connector.
(III) You can find "New B3 Stepping Chipset" logo on the UEFI BIOS boot screen.
