I've sent my Desire HD back THREE TIMES!!!
6 Nov 2010
here and there
My dream phone arrived last Friday from t-mobile, its absolutly fantastic, but after a few beers and a few you tube songs i noticed the videos shuddering and freezing. I tried and tried in different locations but just the same.
So i sent it back and t-mobile agreed a complete exchange. Another brand new Desire HD turned up on Tuesday, straight onto You tube to play a HD video... exactly the same, freezing, stuttering, jittery videos, i couldnt believe it. So t-mobile agreed a THIRD complete exchange.
It will arrive tomorrow!!... im dreading testing a you tube video, i so want it to work as the phone is gorgeous and genius.
Anybody else had this problem?????????????
I'm certain the DesireHD hasnt got enough grunt to run HD clips off youtube - i dont even think the new dual core phones can do it.
I've never had any issue with youtube clips juddering or anything of the sort - I certainly wouldn't go to the effort of having the phone replaced 3 times just because of that?!
Are you sure you've got a good HSDPA signal or if you're using wifi is the connection a decent one as well as the initial Q regarding the actual content you're attempting to play?
I found that setting USB debugging (settings/applications/development/USB debugging) to on (ticked) eliminated my video stutter, and other lag issues.
Ginga
Ginga's post will most likely resolve your problem, but you also need to check your downloading at a suitable bandwith, if its in the region of 350 kbps thats only a 3G connection, you should get upwards of 1000kbps for HSDPA (or 3.5G as our Nokia friends see on their phones :)
