nope (you wouldn't hear the engine note change so much if I did) just more rear end grip than you get on the bike - working on a home made fully electronic shift system with cut & blip, as currently it's all manual - should be fitted soon
The 911 has a real gearbox (Either manual or PDK, doesn't matter, both will be better than the V's slushmatic). Its also 25% lighter and has 4WD to put all that power down. Its closer than the pure power figures make it seem
Then look at the prices. A new CTS-V will set you back $65k without ticking too many boxes, then add the V650 tuning kit for ~$15k. A stock Turbo runs to $136k before options
This is why I like it, then again I love most things Hennessey do. The VelociRaptor, Venom GT and CTS-V are all totally unnecessary and total awesome as a result
