Hi guys, I have a bit of an issue that has apparently randomly occurred.
Specs:
Windows 7 Home Premium x64
4GB RAM (2 sticks)
2x 1TB Drives (one has Windows and the majority of my documents, one has various videos archived on it.)
ATI HD4850 512MB
Gigabyte MA770T-UD3 Mobo
While playing Eve Online I copied a chunk of text, about a second after copying it, the screen froze and a BSOD flashed up for a few seconds, enough to see the words "SYSTEM_SERVICE_EXCEPTION" (google says this means nearly nothing without the STOP code).
I tried rebooting and was given another different Bluescreen: PAGE_FAULT_IN_NONPAGED_AREA and it mentioned the file CI.dll. It then rebooted nice and quick before I could get any more information.
Safe mode gave the same bluescreen, so I booted from my Windows 7 DVD and attempted to use the startup repair tool, which told me it repaired the file table (or something to that effect). This worked the first time, allowing me to get back into W7 and run an AV scan, watch some youtube videos and launch Eve again.
After about 20 minutes of Eve, the first bluescreen reappeared and this one caused even more issues. Booting was the same as before; CI.dll is broken. Booting from the Windows DVD worked until i attempted to use a repair tool, then it displayed another BSOD, but i got the error code from it:
STOP 0X0000003B (0X00000000C0000005, 0XFFFFF8O00C082071, 0XFFFFF88008897240, 0X00000000000000)
After a few more attempts using the Windows DVD I managed to make it run the startup repair tool; it fixed the following issue by doing a system restore:
"Unknown Bugcheck: Bugcheck 50 - Parameters = 0xfffff14014581bf0, 0x1, 0xfffff88000c5b531, 0x7"
This allowed me to boot, but then I bluescreened at the login screen with the same CI.dll error. All subsequent BSODs have been at the Windows loading screen.
Currently I am apparently able to run various tools from the Windows DVD, so I have done a Memory Test which looked clear, and am currently running chkdsk on the boot drive.
So, with this long post behind me I am wondering if any of you have experienced a similar problem, or can offer help. I have googled around for help with the STOP code but cant find anything directly related. I also found that CI.dll is the dll that checks the integrity of windows files, which may suggest this was caused by a virus of some sort.
Thanks for reading.
			Specs:
4GB RAM (2 sticks)
ATI HD4850 512MB
Thanks for reading.
