I'm guessing £450-£500 here, more towards the latter on launch![]()
What a way to celebrate the recession huh?
While we cannot reveal the specifications or framerate numbers to you today, we will say this, we are happy with what AMD has provided. The specifications are everything HardOCP had hoped for. We think gamers will be pleased with the hardware. This video card is better out-of-the-gate than the Radeon HD 5970 ever was.
What other failure's ?
I'm not sure your to sure.
They do comment things like
so nearly twice?
Well we get big performance hints. The HD6990 running stock is faster than a max clocked HD5970. A clocked HD5970 can be over %20 faster than a stock card.
The Radeon HD 6990 video card will be the successor to the Radeon HD 5970.
yep, if you read the results closely, you could work out with using a pair of 6970's and clocking them to get roughly the same framerates/results they did to get an idea of its performance numbers.
We found this very playable. We can't tell you the framerates, but we can tell you they would make you smile.
This was playable! Indeed
What we saw proved that both GPUs on the Radeon HD 6990 were accelerating this game "properly."
In some parts, it was actually playable, but in others, such as battle scenes it wasn't.
However, in this game, we actually found Anisotropic filtering to affect performance to a large degree.
And i think i may be skipping then 6990 and waiting for the 7990... unless my 5970 dies
errr....okay maybe I read a different article than you because the one linked to in the opening post only mentions the 5970 twice on the first page.
More than likely what I will do - unless I find I can't max out Skyrim![]()
