New Build approval please
30 Nov 2008
Hi all
I have finally decided to build a new system, just wanted to know your opinions on it. Also I have not included a PSU as I already have a bequite darkpower 650w which I assume should be fine with this set up.
EVGA GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £299.99
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail £263.99
Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £149.99
Fractal Design Define R3 Midi Tower Case - Titanium Grey £84.98
Corsair Vengeance 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit ***OcUK Exclusive*** £62.39
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £26.53
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £39.98 (£33.32)
Total £940
Ah forgot I will need win 7 64 bit......I currently have this (homepremium) on my current system, can I reuse the key for this as my old system will no longer be using this (selling the parts to recoupe some of the cost of this new system)
q1) Do I really need a sound card ?
q2) Is there a better set up for this kind of budget?
q3) Have i forgotten anything?
q4) Do i need aftermarket TIM ?
Many thanks in advance
you could save £100 by getting a gtx 480 and use the diffrence for a 2600k or an ssd?
the psu would be fine either way
thanks for a quick response, I am already choosing the 2600k, SSD is way too expensive now adays, however, the 480 may be good, but i think it runs hotter and has more power draw??
I wa slooking at 2 threads at the same time and thought i read 2500k
it does, however the power draw isnt massive diffrence, and £100 is a £100 for pretty much the same performance and would get you a 60gb ssd that would make the pc feel massivly better
Ive used oem windows on more than 1 system you may need to ring microsoft up when you install but thats all and its a free number so no big deal
