Yes and yes.
really? thats awesome.
does angry birds run 100% fine? (no slow down)
what rom are you using dude?
Yes and yes.
/QUOTE]
No, that's with mine clocked to 710 with JJ9. It's smooth on the early levels but slows down when things get busy.
which one would you lot choose between the SA and the galaxy apollo?
I'm having problems rooting the phone, I enter fastboot-windows flash boot boot.blade.superboot.mcri.r3.img into command prompt but it says it isn't a recognised command etc. etc., so I dunno what I'm doing wrong![]()
Make sure you change the dir to where the files actually are. By default on Vista/7 it's C:/Users/Administrators I think.
cd.. to go back one step.
That worked, thanks
Edit: Lol, just rebooted it and the Orange logo is blue.. hmm I think somethings gone wrong, after I turn my screen off it won't come back on and it looks all washed out
Edit2: all the Orange apps are gone even tho I've only rooted it (Ive not installed a custom ROM yet)
Superboot was only meant for the OLED sanfran phones, you've got a TFT screen and need to use an updated boot image.
is it ok using ClockWork Recovery Mod then?, and kinda my luck getting a TFT 1 instead a of OLED![]()
Here are some instructions from modaco that should sort it for you. It's a little old now, so make sure to get the updated versions of clockwork, etc.
http://android.modaco.com/content/z...oblem-after-flashing-superboot-on-tft-device/
Hi, anyone have a white san fran??? what are peoples opinion on the white..opposed to the grey?
They look significantly cheaper, the grey one is a lot more htc like. Also the white one has a more polished finish too, grey one has a more dull/matt finish.
Get a grey one.
Get a grey one.
