Yes it's on when the system is on not when the system is off but power is connected.
I've built many PC's over the years. On none of them is the power LED on unless the system is actually running.
There's something wrong with the wiring. Check you've connected the front panel connectors to the motherboard correctly and check that there isn't some mistake in the case wiring, i.e. that the power switch is actually connected to the power wire etc.
A test you can do is firstly disconnect all the front panel connectors from the motherboard. You can then try and start the PC by bridging the two pins on the motherboard for the power switch with a small flat bladed screwdriver. You only need to touch them you don't have to hold the screwdriver there. If it doesn't start using this method then you have other problems.
Anyway, off to work now so good luck.
And check that wiring.
it may not be the motherboard, do you have another psu to try in it ?
