After reading this thread I will try quakelive and I am currently installing ut2003 but I have a feeling disk 2 is scratched badly and wont install.
I heard that was nerfed and it's too easy/no skill?
Compared to which game exactly ?
I really should get back to QL - only really touched it during the beta many years ago and now my PC is not my main system anymore. Does QL feature CTF and which versions? Does it have the OSP or 3W maps too?
ps3ud0![]()
Cheers oL - for some reason I had recollection that QL originally was 1v1, DM only, but as I said it was a very long time since I last used it, I know it supports Mac but I wont be playing it on a MBP.
Shame the frame related physics has gone, did they get rid of the wierd Q3 bouncejumps (cant remember the proper name - if you were a certain height on certain parts of map, jumping on a point would mean u could bounce back to same height)
ps3ud0![]()
Generally people are comparing to q3 when they say this.
Although ql is for all intents and purposes the new, modern, q3 there are still significant gameplay and engine differences between the 2 games.
Just found it - they were called overbounces and caused by enabling pmove and jumping on particular parts of the map - was found out by trickjumpers quite late in Q3s life - pretty sure it was in one of the opcpromo vids - will try and find which one...About the physics, I'm not sure what you mean about "bouncejumps", perhaps you mean doublejumping / chainjumping, which was implemented into QL a while ago. Basically where if you jump off two "edges" of objects in quick succession you will gain speed. I do know that the physics are for the most part, the same as they were in Q3.
http://www.own-age.com/vids/34/stream/
Watch from the 55sec mark for a few seconds and youll see what I mean - b3nt f t w...
ps3ud0![]()
Do people still play unreal
that was a great game. Does it run ok with windows 7 can you still buy that game
