Mine doesn't on CM19, you just need to set 'Always use proximity' in call settings, and it works perfectly now.
ah right, excellent can mess with her phone again which will please her lol
does it still suffer the blank screen after a call prob?
I've had this phone for ages now. Not moded. Why is it NOT advertised like other phones.
Everywhere you go you see the HDC and others advertised like heck but never the SF.
Did Orange shove this out for testers/mods to test it to heck before doing a better one.
My Battery runs out in Double Quick time when I got my GPS and/or 3G is on.
Should I switch both off or just leave the 3G on??
i appear to have bricked my phone![]()
Has anyone had any luck with orange replacing a SF even tho the phone had been unlocked?
Oh dear, what have you done ?
Did you do a clockwork backup?
wanted to try a new rom so updated clockwork then flashed to cm7 n19 and now it just android logos loads splash of cm then reboots.
reflashed still same
flashed a different rom and does exactly the same
any ideas? couild it be the sd card?
sadly not. i think it might be since i've updated clockwork. i had 3.0.0.4 previously and it flashed fine multiple times. how do i go about installing an older version of clockwork as i guess the update option wont work
I doubt they could tell. Just return it.
