Unplug/disable your 2nd monitor and reboot before you do a new install.Yes im running dual monitors that is interesting
Interesting replies I think only a new windows installation is gonna fix it tbh :/
Presuming your talking about launching gpu-z at startup, then create a shortcut and put it into: Start>all programs>Startup.Umm... lol nooby question but how do you do that again?![]()
disabling ULPS stops the second/3rd/4th card from powering down (core/memory) going to 0 at idleNope that's not the issue, you only really need to disable ULPS if you are overclocking. Doesn't fix the usage issue.
