This is a fairly urgent case spec
Younger brother bought himself a new GTX 570 (one of the Asus Direct CU II ones), and we've just found out the 570 is about quarter of an inch too long to fit into his current case.
Hence we're looking for a new case that can take a Graphics card that is about 11 inches long, has reasonable cooling (preferably quiet) without costing a fortune.
I normally like Antec cases but I don't think they'll work in this instance as his other requirement is that it should be under 60cm high - 55cm is preferable as it has to go under a desk.
Price as far under £100 as possible
although I suspect it's going to cost £50-75 at least.
What he doesn't need is lots of lights, case windows etc just something functional (although a case window isn't a deal breaker).
