Just giving anyone who doesn't want to break the bank on CPU cooler a heads up on this Cooler Master cooler. Bought this just over a month ago for £12.49, it's basically the cheapest non-stock heat-sink that Overclockers stock, before then I was using AMD's stock cooler which idled around 30-35C and went up to 60-65C under load on an overclocked Phenom II X4 945 at 3.75Ghz.
With this cooler i'm getting around 18-21C while idling and browsing the internet in a 20-22C hot room and around 40-45C under load, pretty impressive for a £13 bit of kit I think. Here's a picture of the idle temperature:
Only downside is it's quite fiddly to work with, especially if you have big hands like myself. Managed to **** it up 1st time trying to line up all the mountings so had to take it off, wipe all the thermal compound off and re-fit it. I also used the thermal paste supplied with it, i'm assuming if i'd have used something like the Diamond 24 Carat compound my temps would be even lower though that costs £15, which is more than the cooler itself.
Will do a Prime95 run tomorrow when I get back from work to see how well it fares, so far for gaming and general use it's been excellent.
Anyway, sorry to sound like an advert but I just can't get over the amazing results this cheap bit of kit has provided!
