New wiper blades
18 Oct 2002
Cambridge
I'm in need of some new wiper blades for the Focus (mk2). Is there any benefit going for after-market ones like Valeo or Bosch or should I just stick with Ford OEM?
Are yours broken, or just streaking?
Good way to replenish wiper blades..
Rinse the screen with water, then wash with soap & mitt, rinse well with water
Now get some clean newspaper, splash a load of vinegar on it and rub your screen in up and down motions. Also, put some vinegar on an old cloth and run each wiper blade a few times until no more grime comes off them.
-Obviously if the blades are falling apart, get some new ones
People rave about Bosch blades on here
OEM ones will usually always be BOSCH or something like that anyway.
If your car looks fine wearing aero flat wiper blades that cost a tenner or less for a pair then get those, they last as long as OEM ones and look better as well unless your car has skinny wiper arms in which case they look a bit odd. If you're using them a lot then even if they last 3 months they're cheap enough to be worth 2 pairs anyway :p
Tesco wiper blades ***!
I use PIAA silicone personally.
You laugh but I actually use the tesco ones on the car.
They don't last as long as others but are fine until they do go, and they only cost £3.00 each when on offer for the aero blades.
Pretty sure they are the originals on the car which isn't too bad considering it's a 55 plate!
The front wipers ironically clear much better on the up stroke than the return stroke. All three wipers skip and make a graunching noise if used when it's persistent drizzle rather than proper heavy rain. The front ones are the flat type whereas the rear I think is a more conventional unit.
I'm leaning towards the Valeo on price/rating ratio at the moment...
I just buy bosch ones off wiperblades.co.uk
Cheap and cheerful.
I think I bought Valeo ones, too.
They're all the same, whatever :p
I bought wiperblades.co.uk own brand of Aero Twin Wipers, so far they have been brilliant, cost me about £15 for all 3 wipers IIRC.
They've been on the car a few months now and no signs of skipping/juddering yet.
I bought cheap aero blades once, the end fell off the balde, I did not notice in the rain and it scratched my windscreen.
Never again will I buy cheap unbranded wipers.
As mentioned in the other blades thread, the unbranded ones come from different places even if they look similar and are built to different qualities. You're bound to get an unlucky naff pair at least once!
Which will last for about a week before they smear, skip and bounce across the screen!
To be fair, my Tesco ones last about 60-70% as long as Bosch ones yet cost £3 when on offer.
No brainer to me.
Unless you like telling everyone you have Rally spec wiper bladez y0! of course :p
My Bosch ones lift themselves off the windscreen at 95+.
Annoying, seeing as I wouldn't mind seeing where I'm going in the rain at those speeds..
