***10% DISCOUNT - On Gigabyte GTX 480 SE Graphics Card - with special voucher code INSIDE!!***
Ugh if only i had an SLi board with a good powersupply! oh and money! :'(
had my gigabyte X58 ud5 2 years now having to run the top card in the 16x lane and the bottom in the 8x for the card spacing, i fancy one of those assassin boards very sexy indeed
It seems my comment caused a bit of a stir, so allow me to be clear :D
Benchmark results I've seen put average frames of a GTX 480 clocked at 800MHz or more within 5% of the 580's average FPS performance. The actual results were from the SOC version and came within 3% over 10 tests.
I was merely saying I've had a modest overclock of 800MHz from my 460, which is a stop-gap, as when I built my PC the 470 and 480 were hot, noisy motherbleepers, and the 500 series wasn't out yet. If I could get anywhere close to that, say, 775MHz-ish, by just bumping the core clock up in Afterburner I'd be more than happy to save the £37.50 over the SOC version.
I wasn't implying the 480 was as good as the 580, because it's not, and I understand that an overclocked 580 would leave it behind, but at factory settings on the SOC and 580, in the real world, you won't notice the difference.
*Dons Ace Ventura costume* - This house is clear :D
i dont know what everyones fussed about lol the fact that you can pick up 2 gtx 480s for the price of a single 580 is a bargain in my opinion
Hi Guys, I am almost very tempted by this card (would mean an upgrade to windows 7 ) especially with crysis 2 round the corner but want to know if it will run fine with my overclocked i7 on a 750w PSU?
I bought a machine 2 years ago, around the same time, as bday present and with my birthday coming up next week have started thinking hey why not...
Current spec is:
i7 920 2.66Ghz (Nehalem) - clocked to 3.6Ghz and mounted on Asus P6T Deluxe cooled by Noctua NH-U12P Cooler
G.Skill 3GB (3x1GB) DDR3 NQ PC3-12800C9 (1600MHz) Tri-Channel
BFG GeForce GTX 260 OCX 896MB
Western Digital Caviar Blue 160GB SATA-II 8MB Cache
Samsung SpinPoint F1 750GB SATA-II 32MB Cache
Western Digital RE2 500GB SATA-II 16MB Cache
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter
Powered by: Zalman ZM750-HP Heatpipe Cooled 750W Modular Power Supply
Maybe a bit overkill on the info but just want to sure.
Also anyone know the cheapest way/place other than the naughty way, to get a copy of windows 7?
thanks in advance.
Leewom ;)
Thanks for replies fellas
now I just need to battle with my mind over the cost...a lunch time decision methinks....
Just to throw it out there, would anyone be interested in a BFG GeForce GTX 260 OCX 896MB? I know its an old card but has done me very proud ;)
You can pick up an OEM copy of 7 Home Premium for around £70. With OEM ones I think you just need to phone Microsoft and let them know if you upgrade your motherboard, and that'll allow you to use it on the new system as far as I know.
Snagged. Was umming and arrring over the SOC, but this for £40 less, and same cooler and PCB... yus pls :D
And just in time for Crysis 2 as well 8)
You sure about same PCb Ie 12 phase power design like on the SOC ?
From pics it looks exactly the same. Just lower clocks.
*shrug*
TBH I'm not rightly fussed, £40 less swung it for me.
Just hoping my 620W Corsair is up to it :o
RAGE. Got the ASUS one two weeks ago and wouldnt have minded that cooler for an extra £8. I hate you OCUK.
*shrug*
From what I've read it's the same card if it makes you feel any better :D
A 620w PSU should be more than enough. A friend of mine is running an EVGA SC 570, a 9800GTX as a PhysX card, an i5 2500K overclocked to 4.0GHz and about a bajillion hard drives on a Corsair HX 520w PSU and it's drawing nothing like 520w. Power requirements are (usually) blown way out of proportion.
A 620W Corsair PSU will be fine, remember that the 620W is its max. I use a 850W PSU, my system doesn't draw anything over 400W, but its nice to keep some headroom and to know my PSU isn't straining away.
I had a look around earlier (not that it matters) - and couldn't work out one way or the other whether the SE is:
(1) A reference GTX480 - as a Rev 2 (for that SKU) with the Windforce Cooler
(2) the same as the SOC - but non-overclocked
I'm guessing it doesn't have the green LEDs etc of the SOC (who cares) - but I did wonder whether it had the 14 phase VRM Power (6 on standard 480) of the SOC
all I could find on the internet was that that SKU Rev. 1 was a GTX480 reference, and Rev 2 had the Windforce - but could find nothing else out
anyone else ?
anyone else ?
I ******* care!
My SOC seems to be dead and if the SE doesnt have the leds im going to ask for a replacement instead of getting a refund and an SE
