Look what happened to them !! Put them underground and power them from the reactor for starters !
Why did they fail??? Surely the very cooling system could be powered from the Reactor on it's own, no????
Maybe to stop people from getting into a panic and making the situation worse.
I hope they get these reactors under control because it will cause lasting damage to not only Japan, but any thought of using Nuclear energy in general. Yes they have safer systems these days but that's what they said about Chernobyl when they were building the Japanese reactors.
Aircraft engine will only blow up if the oil pump fails or birdies fly into it (A380 Trent engine had an inherent design fault) , then we can shut it down and do an emergency landing... Not so simple with a Nuclear reactor. Jet engines use the fact they travel at 30,000 Feet to be a cooling system (it's very cold at that height) ... Reactors don't have that luxury.
The engine was designed to withstand a blowout including blade disintegration, yet still be able to land safely. The outer shell of the engine is designed to contain such a problem and prevent debris from damaging the wing (in particular the leading edge slats). What happened on the A380 flight could never have brought the plane down unless a fire broke out, which in any case can be controlled using standard extinguishers (deployed from the flight deck).
I know this because....
the reactor was shut down and not producing power, had all reactors been left running we could have ended up with a worse disaster.. (however it looks like at least one is going to start reacting again anyway). I'm also sure the cooling equipment is not directly powered by the reactor anyway... if must at least go via some sub station that would ahve been trashed in teh wave..?
You've ignored answers to all your questions many times over, I'll give it one more try. They were underground, there was this little thing that happened called a Tsunami, Diesel generators in a sealed room putting out fumes with no cooling would fail, hence the room isn't sealed, so one room, below ground level, not sealed, plus millions of tonnes of water above ground level. For about the tenth time now, the diesel generators failed because the building was flooded.
Why weren't the cooling systems powered by the reactor, because the reactor was shut off, why was the reactor shut off, because if they lost power links which is quite common in a huge earthquake, let alone a tsunami knocking power links over, or cooling had failed, things could have gone badly at full power. Remember cooling draws in water from the ocean, the Tsunami has a ridiculous amount of force, it could have damaged the cooling pipes, blocked them, thrown debrie from the ocean floor, or forced I should say, up the water pipes. Any number of things could have gone wrong so you shut the reactor down when a big "event" happens.
So I've been told 2 of the reactors were putting out close to 3000MW's of thermal energy at full capacity, the failed cooling and current cooling methods are having trouble dealing with the shutdown thermal energy which at this stage should be less than 1% of full capacity, or 30MW, it could be as low as about 0.5%, if the reactors had stayed at full capacity, and the same cooling problem had happened, almost certain reactor 2 and 3 would have had a full meltdown within a few hours.
Yes, in hindsight MAYBE keeping them on would have been better, in hindsight everythings pretty easy to get right.
The overwhelmingly safest choice in an earthquake in that situation is to shut down the reactor.
Some unforeseen effect of a huge tsunami possibly compounded by earthquake damage. It's too early to speculate.Why did they fail???
I assume you mean using the decay heat still being generated by the reactor after shutdown. The Advanced Boiling Water Reactors (ABWR) are able to operate in this manner but they came into service a quarter of a century after Fukushima was built. In fact all third generation designs incorporate various passive/self powered cooling systems in case of total power loss.Surely the very cooling system could be powered from the Reactor on it's own, no????
Our government did such a good hush job almost no one has heard of WindscaleWhy do BBC compare it to three mile island and not our own nuclear accident...
http://www.lakestay.co.uk/1957.htm
Why do the rods produce so much heat with the control rods down?
Surely the reaction stops or is all this heating issue from the natural heat produced by the rods?
