- 30 Dec 2005
- Calgary
I wouldn't bother with the fairly liquid, there is no need, I'd want as little chemicals on there as possible, water should get rid of bleach fine.
nope, the majority of germs will be destroyed from the bleaching.
then you'll add more from the tap water
just do it the normal way, in the lighter for a min then off.
Make sure you rinse it!
I didn't actually know what a skin tag was until now so googled it - really wish I hadn't![]()
Its only a skin tag, not like youre amputating a leg. Just rag it off.
Man alive, sterilizing the clippers for this isn't even needed.
Unless you have a really crap immune system. Do you have AIDS OP?
