Sterilizing nail clippers at home... Quick Q!
Unless you store your nail clippers in a warm, damp cupboard that is frequented by local vermin, I don't think you really need to sterilise it, just give them a quick clean in hot water.
Man alive, sterilizing the clippers for this isn't even needed.
Unless you have a really crap immune system. Do you have AIDS OP?
Aye docs "kill" them with a small band or knot of fish line type stuff.
I suggest napalm TBH.
Boiling water for 30 mins would be fine.
If they wernt metal a microwave would do a good job, well in fact it will still do a good job and with a free fireworks display ;)
If it was very small I would have actually suggested a brand new top quality razor, should get a lot closer to the "level" than some clippers.
If you really must.....
Just boil them in water.
Cut the skin tag and dress it and keep it clean until it heals.
Tbh, you don't even need to do that unless the skin tag is pretty huge. I lopped one off with a pair of scissors once, it bleed a bit and that was it.
