Its true HT is a bit overrated, but still its a feature you paid for. So if it was me i'd RMA, as all that will happen is you'll get a shiny new chip.
Worst case scenario: New RMA chip won't clock as well.
Best case scenario: New chip clocks better.
Unlikely scenario: They accidentally sent me a hex-core...![]()
unless the cpu has been burnt to hell and is blacker than the black hole of calcutta how the hell would intel know you overclocked it anyhow, its not like the cpu has got a built in audit trail saying 'yes I was abused to hell and back , my last owner pumped elventyten volts through me and jacked my multiplier up to infinity and beyond ?'
Um...not sure the second point is true. I think it comes from an individual forum post some time ago that was later debunked, and which has been propogated by AMD fanboys (obviously not implying that you are one!) ever since.
What *does* void the warranty is if Intel determine that a damaged processor was caused by incorrectly applied thermal paste, or an incorrect heatsink mounting. I assume they look for specific things like thermal paste residue on the contacts, or a damaged IHS.
Also there is NO way at all Intel can know if you've OCed a cpu. Again, there was a forum post a while back where some fool said that Intel CPUs have a permanent memory cache or something.
EVen if they asked you the standard questions 1. Did you use this above the rated speed ? - Answer, no, not sure I know what you mean there boss ? Followed by question 2 what heatsink were you using ? Answer I used the standard Intel HSF tha came in the box with the CPU.
Unless Intel have a secret service division akin to the Mossad and had planted spy cameras in the box to observe your fitting of said CPU there is no way they can accuse you of anything other than what youanswered above in 1 and 2
Actually, there are lots of little people that live inside cpus. They're the ones that do all the processing stuff. When you put more volts through them they hurt like hell.
In my bios i can change if i have ht on or off, i can also change how many cores i have active "all, 1, 2, 3, 4" , if i turn ht on i only get the "all, 1, 2" options but if i turn it off i get "all, 1, 2, 3, 4" all my cores, it is sadly nothing as simple as my os![]()
