So ladies and gents, was fermi a fail after all?
I know this has been asked loads before but while I am here how do the GTX480 overclock like, it will be under water so heat shouldn't be too much of an issue, it would be the Asus GTX480 I am thinking of getting as it looks like the SOC version is not stock PCB
Very good clockers. No, the Gigabytes aren't ref designs.
tell me about it :(
You must be cursed. My friend is cursed badly when it comes to technology. He has problems with everything he does, and it's definitely a curse because I often redo things for him, in the same steps and it always works for me. :p
my iPhone, iTouch, old comp, mouse and speakers have also died :(
... Everyone is entitled to their opinion, but when you're very selective with your examples, you should expect others to point it out.
I wont bother tbh, don't see why you need to make this a problem.
Anyway on topic: Fermi was fine, you either like it or you don't.
Cleeecooo, have you thought about getting an anti-static wrist band?
LOL. I have one. The thing is, these things don't die when I handle them -just when i'm... around :(
My 5850 - never OC'd
480 - DOA
iPhone 4 - bricked itself somehow - before i was going to jailbreak
iTouch 3rd gen - Just... died :(
My bad luck is one of the reasons i want NV so badly. NO ATI BRAND HAS DECENT CS
I'm not making it a problem, this is a discussion forum, I'm discussing, and the point was, not everyone thought Fermi was fine, hence this thread. Fair enough if you think it was fine.
480 - DOA
I think you're cursed when it comes to RMAs too, as I've had no problems with ATi RMAs and so on.
Ive had my 470's a while now, still extremely pleased with them, got the heat/noise issues pretty much tamed, due to a combination of good case cooling and custom fan setting. Power consumption is high, but not as much as i expected, particularly in normal gaming, 530w ono with the spec in my sig, cards oc'd as well.
