- 21 Mar 2011
Did you have to buy the graphics card to record HD sound or did you buy the graphics card to playback the media on the server itself?
I was speaking to a mate and to get HD recorded i need to use a DVB-2 or something and there is hardly any out + i dont have freeview HD just wanted be futureproofed.
I would transfer the files to the other pc or an external usb drive if the quality was to poor using the wireless.
You need the graphic + sound card only for playback. For recording you only need the tuner. AFAIK almost every digital tuner nowadays supports both SD and HD, as they only transfer a stream to the hard disk and/or to the playback software. The difference between SD and HD is in bit rate and/or stream format, and that's a matter for the playback [hardware + software].
You may try the wireless; if it doesn't work reliably you can either transfer the files (but it's a bit boring) or use wired or a powerline ethernet adapter.
Cheers
