Ive seen a few tests on good sites and its normally 1 or 2c max at load.
But if your getting 5 6 them that's a nice drop
Can't beat a proper kit. My rx360 keeps things nice and chilly
wouldn't mine one of those monster tho but just to pricey
i had a monster tfc
bought it for my latest rig but when i plumbed it all in i realised my 5970 wouldnt fit...totally gutted...i had sprayed it copper and it looked awesome...tried to mod it to make it fit but still no joy....ended up binning it because i had cut a few bits of when modding and didnt think i could sell it like that...that gutted feeling is coming back just writing this![]()
hi chk4, just had a look at your case and i would have it so all fans are sucking cool air from outside the case apart from the big one at the top which will exhaust the warm air.... so side fan,front fan and fans on h-70 sucking in to the case and 200mm top fan exhausting the warm air....thats what id do mate
im gonna try this, i set my h50 up to blow out the air.. probably inefficient
Hey mate no offence taken, I ordered a pre configured overclocked bundle from OcUK. It never ran this high until I put in my 580.That is way too hot still though, for a CPU. Id be looking at how youre mounting it and things like that as those temps cant be right if all is installed correctly, surely? No offence to you ofcourse, just really baffling.
chk4...can you give me some info?
1. what i7 do you have
2. what voltage are you running it at
3. do you have speedstep enabled so that it only clocks up when you need it
4. what paste are you using
4.2 is quiet a high clock and to many extra volts would cause excess heat...maybe we can get it cooler yet....
also when you tighten down the four cpu cooler nuts did you tighten them down equally and not spin one down then the other etc etc?
these need to be spun down equally so that there is even pressure across the face of the cpu...this is important
Hi mate, the way the H70 cold plate has the paste is that it's already evenly spread out if that makes sense.101 is fine for PCIE. With the thermal paste, you need to use as little as possible and put about half a grain of rice's worth on the centre of the heatspreader on the CPU. Then use the heatsink to spread it out as you tighten the bolts down, it needs to be fairly well screwed down but not too much. Difficult to explain it just has to be done by hand really, but having too little pressure will mean the paste doesnt spread out enough and temps will likely suffer.
Good luck![]()
This was at 4.2 so since the 580 the temp really has shot up. The 51 degree while playing game is what I was getting last night but still my CPU is 10 degrees hotter now under stress and 10-20 hotter when idle... Damn 580! lol.30-40 degrees while idle
51 while playing Crysis (everything on ultra)
71 while under full load stress testing running @ 4.2 for 30 mins
Thanks a lot matecan i just say...thor....you are a god!
what a cool name...sillyness over...
you want to get speedstep working that is going to help massive with your idle temps...when your ready give me a shout and i will go through it with you....getting some mx-4 will make a difference to it....clean it of properly though as a greasy mess wont help.....you get special stuff for this......when putting the new stuff on all you need is a pea sized blob in the middle...do not be tempted to put more on as this will work against you..all you need is half a pea sized blob in the middle and a frozen pea not a big fat garden pea.....
screw it down alittle from each corner so its an even pressure...change it back to 100 from 101 but this wont make much difference.....did you buy new fans for the h70 or use stock? this will make a BIG difference...... your 920 must be a d0 because a c0 revision wouldnt go to 4.2ghz,thats a massive overclock for a 920 its definatley on its limit there...check the volts out for me and let me know and we can talk some more and see if we can get it lower still
speedstep and fans/mx-4 will lower it more though
http://www.overclockers.co.uk/showproduct.php?prodid=FG-004-NC&tool=3
these are what i use...great great fan ive got 6 of them on my rad..expensive though
fans and mx-4 should get you into the mid/late 30's which for 4.2ghz is pretty good...try lowering the vcore down to 1.29v and see if its stable then try 1.28v and so on till it bsod and that will lower temps also....its worth a play...you know if its not stable the back to 1.3v..
one thing i just noticed? does that say (ES) on your chip?
that would make it an engineering sample...did you fit that thor?
ocuk wouldnt have fitted that...
