Nah, full replacement discs and pads all round will be about £400 + labour.....suspension and radiators on the other hand.....![]()
Not at an OPC it wont be 400 quid, and if he wants a warranty thats where it will need to go really.
Ok understand the risks with warranty so will consider this carefully. From where I am sitting at the moment 1k for piece of mind is fair, if the car performs without fault ive wasted 1k if it doesn't and the engine goes pop i've saved 3k.
Swings and roundabouts I guess. Either way its looking like the normal prestige car issues, expensive parts and labour but by the sounds of things these cars are pretty reliable.
There's no way I'd take an 02-05 car to an OPC for servicing - can you even get an OPC warranty on a 6 year old car?
The £400 is the price for the OEM parts, but what an OPC would charge on top I don't know.
Personally I'd spend a couple of hundred on a specialist inspection then use the same place for servicing and gamble on the IMS.
- Like yourself I have no fixed budget but have wanted one for a while. I have therefore set an upper end budget of 15 - 18k including the trade in of my 08 car.Think this is what my plan is going to be... he who dares wins and all that!![]()
I'd say with a 6-9 year old Porsche Boxster S with no warranty you may well lose, unless you aim to get one that's already had everything already done instead of going for less than XX miles or something.
What's that thing I read about getting a stone in the wheel/brakes and it costing thousands?
/Looks down at his Burton suit
18K should get a 987, which seems to reduce the chances of IMS failure
- has more toys and the right wheels though.Seriously forget the 02 car, get a later one. Also try a tiptronic before discounting them, they drive great.
If you have 16k and want a Porsche spend it all, dont think a 12k will be a bargain.
So you should only buy a Porsche when you need all the help you can get to look good![]()
