After much deliberation i bought as an upgrade...
Intel Core i7 2600k 3.4GHz Socket 1155 8MB Cache Retail Boxed Processor
Asus P8P67 Pro R3 P67 Socket 1155 8 Channel HD Audio ATX Motherboard
Corsair 4GB (2x2GB) DDR3 1600MHz/PC3-12800 XMS3 i5 Memory Kit CL9(9-9-9-24) 1.65V
Im sick to death with the noise of fans, i have the corsair H50 and even that is winding me up...yes, thats how quiet it is my house !!
Im looking at the RESERATOR1 V2 Fanless Water Cooling System with which comes with the following..
100% fanless watercooling unit
Supplied with CPU water block (ZM-WB5 PLUS)
Supplied with VGA water block (ZM-GWB3)
Supplied with anti-corrosion coolant (ZM-G200)
Supplied with quick release couplings and clear tubing
I will need to get an adaptor for the water block to fit my motherboard as it is socket 1155....my burning concern is the aluminium and copper problem..obviously it whats on the inside of the block that is in contact with the fluid but i cant get a definitive answer as to what material is on the inside of ZM-WB5 PLUS, it states.. and here is the link..
http://www.zalman.co.kr/ENG/product/Product_Read.asp?idx=342
"Pure Copper (Base), Pure Aluminum (Cover)"..well, whats on the inside ?? clearly the photo on the website shows the contact surface to be polished silver/aluminum or some other plating.
My graphics card which i have also been told in another thread is crap, is an nvidia 9600 GT (does me, i dont play games...yet)..the supplied block for that i am hoping will fit the mounting holes although not stated as compatible on thier website but then nor was thier fanless heatsink but it fitted !!...any advice on compatible water blocks ?
All this is going into a rack mount case in my front room..im am adamant i dont want ANY fans...i only have 1 SSD hard drive in the unit so no heat from that, the only heat will be coming from the GPU and CPU..is it worth looking for a full water block for my graphics card ?..i have the plate covering the ram chips seperatley from the fanless heatsink...i could leave that on maybe ?...or a cheaper upgrade to the grapics card ?
