I live in a village and I don't really have too many options... also switching IPS'a would be to easy for them.
Does that not suggest the infrastructure is at fault rather than the ISP? This doesn't sound very well thought through....
Your the only one suffering, they aren't. Just move isp. Can't believe you've put up with it for so long.
Also are you on wireless, or is it defo the internet dropping out. Have you tried finding the master phone socket in teh house and plugging it in there.
The problem could well be internal wiring, if you move ISP and it happens at least you know that there is a fualt somewhere.
Who is your ISP?
I am on a 1 month contract and I could easily quit, but like I said I haven't got much choice here where I live.
Regarding my equipment, it's 100% fine. I've had 5 different routers, I even went and bought a brand new router just to find out the same problem...
BT engineer came around my house to check everything and he said it's ok. Though he didn't check the cables from the exchange...
Change to BT, then they can't pass you around between companies playing the blame game![]()
They're under no obligation, according to the contract you signed with them, to do so.I'm not saying it is their fault. It is their fault not addressing the issue properly. I pay them, they pay BT.
Move isp. I would recomend that you consider Eclipse over at eclipse.net.uk they have looked after me for several house moves, line problems etc. Have to say that over what must be 8 to 10 years they have been brilliant.
£42?
You're doing it wrong.
Are you 100% sure? I can't imagine the situation an engineer would go to your house, test the internal wiring for faults then pronounce everything fine without running any line/connection tests with their equipment.BT engineer came around my house to check everything and he said it's ok. Though he didn't check the cables from the exchange...
