Thinking of getting my mum one of these for her birthday so she can play sudoku and scrabble / wordfeud plus have access to her emails.
Most likely I'm just opening myself up to a massive world of pain with an endless loop of "how does this work?" questions from her but is there anything to be specifically aware of?
I'd be getting it from orange and not rooting it.
i am using the modaco rom and my wifi keeps disconnecting. if i go to the menu and reconnect it is fine. anyone elze having this issue?
how do i know which shop sells G1's? no point in buying G2 atm... as much as i know the ones that ship with 2.1 android are G1's?
@Cheetah- what do you mean by the modaco ROM...? Is it the R12 revision by "Paul"...? I did notice that they had fixed some wi-fi issues in revision 11. Which one are you using..?
Yeah the one by paul r12....the latest one
For those that did have issues with WIFI and the modaco ROM, can you recommend me a more stable ROM to goto, I love the modaco ROM apart from the WIFI.
From what I've read on Modaco the Blade's that are sold with Android 2.1 are Gen 1 devices, and those sold with Android 2.2 are Gen 2 devices.
IF that is true, then any UK device will be a Gen 1 device as we only get Android 2.1 in the UK.
It's worth reading info over on Modaco and checking it out for yourself, though.
Or you can look on the market, and install ask mr pigfish. It's for the blade and will tell you what gen it is.
Have you tried the Blade Wifi Fix from the app market?
